Need help wit ideas on what to do wit inner fender ??
87gbodydanny
Apr 1, 2023
54
4
Las Vegas
So one of my main bolt( 15mm) that had shims the nut is strippef on the inner fender . It’s hard to find one anyone have ideas on what can I do ? Anyone run into this problem 1987 regal
86 Salon
Mar 14, 2021
74
80
Either try tapping it to a larger size, possibly SAE instead of metric or just cut off that nut and weld the correct size back on.
Rt Jam
600
597
Ontario Canada
It will ALL depend on if it has to be correct, functional, your budget and skills.
The cut and weld on new nut is the absolute proper method if it has to be correct size. You need skills to grind without damage, weld and paint.
You could just let the stripped nut be a hole and install a new on top or drill and tap to next size.
9,619
12,713
You could also drill and tap it and then use a Helicoil style insert so you can use the original size fastener.
