I have recently aquired an Olds 350 from a "75 H/O. It only had 160 hp from the factory according to a little research. It supposedly ran, but figured I'd look inside and see what I'm dealing with. So far I think I can just clean it and hone it. I wanna do all gaskets, rings and bearings. Then a timing chain and cam/lifters. Its a very low budget rebuild. I plan on running stock cast iron heads and intake. I have #8 smog heads w/ huge 79cc chambers and what looks like dished pistons. Can I just put different pistons in to bump the compression ratio? What would be a good cam for a fairly stock 350? Is there anywhere that stocks rebuilt older high compresion heads like #5 heads or something. I can find some for chevys but not Olds. What kind of power could I get with just a cam and pistons?
