CUTLASS Park dont work
tiwii666
16
2
Canada
Hello i have a th 200 4r and i have floor shifter with column linkage and when i put my park my reverse light is on and my car move so my park dont work can i have help please
Sweet_Johnny
Has A Face For Radio
672
1,224
Wichita, Kansas
It sounds like the linkage is out of adjustment, because if it's not hitting "Park" something has gotten loose or worn out. Unless the indicator has slipped out of position, in which case I'd think you could easily reach "Park".
Are you saying that you have a factory installed floor shift with the factory column linkage so the shift indicator in the cluster still works? I believe I've read about that setup but I have no experience with them.
markolds
12
15
Just went threw that with my salon my shifter cable was stretched and didn't have enough rigidity. Check the bushings at the transmission and at the steering column. You can disconnect the rod to make sure the column is rotating properly. Mine would also stop my ignition from turning off
