Well, yeah, that chrome stamping is hot stamp. Which sucks because it would be kind of a whole lotta expensive to duplicate that. If your chrome is toast, about the best you could hope for is some of the chrome-like paint stuff or a chrome mylar decal of sorts (polyester metalized adhesive film- like that little funky chrome balloon material except with sticky stuff on one side).
In FAAAACCCCCTTTTTTTT.......
I just got done measuring the chrome edging dimensions to see if some thin mylar polyester chrome adhesive tape can be used. I made a template for my decal cutter but I have to get some mylar chrome tape first. If I can make a 3/16"-ish wide perimeter rectangle (one side is 5/32" for some reason), it can mimic the chrome edging. It's an experiment worth doing. If it can be pulled off, it's a lower cost alternative to restoring the chrome edging on the backup lamps. You can do it with small strips, but it would leave seam marks on the corners. With the cutter, it should be one single decal for each side. Not sure how long it would last, though. I'm sure a garage car would fare better, but who knows.
I got a backup lamp set out of an 83 that may need restoring, I'll have to dig it out and see. If it seems do-able, I'll just restore those and try to match up the silver and add the chrome edging and buff them up.
If it works out, might do them in smaller size for the always rubbed off shifter handle perimeter on the shifter PRNDL plate.
