Seat belt retractor broke, Replace, leave it or is there another option?
tkruger
358
310
NY
The passenger side seat belt retractor lever broke on my 1987 Monte Carlo. What does it take to replace these? Is it worth it to make them work as they should? Is there a way to update these to a modern seatbelt that does not use these retractors? I also need to replace a few trim pieces on the seatbelts so if replacement is an option now is the time to do it. If it is better to fix it then all the trim will be done now too, This car is a driver, not a show car.
7,993
18,729
The replacement seatbelts don't use the retractor lever. The stock seatbelt locks if the door comes open, to keep you from flying out of the car. The replacement seatbelts are like what are in modern cars in that bumps cause them to lock as well as pulling on them fast. They take some getting used to.
8,282
17,850
Two phillips head screws hold the lever in the door jamb. There's a gasket behind it, and check the screw holes as years of hiding may show some rust around the holes and the backside.
If you're lucky, you can get the old one out and put a new one in from the jamb, but I've never been lucky. I have always taken the rear seat and lower side panel off to gain access to ensure the flexible rod got placed correctly.
They make a new repro for the driver side that Gbodyparts sells, but for whatever reason, they don't for the passenger side.
GM p/n you seek would be 20020378 for passenger side. (20020379 for driver side p/n)
Rocket350
38
44
Charlevoix, MI
Do you have a link for the replacement seatbelt kit(s). I need a driver's front black for a 1979 Cutlass. Thanks
7,993
18,729
This is who I used....
Rocket350
38
44
Charlevoix, MI
Thanks. I am assuming that I would select the G Body 82-88 due to the updated "modern" pre tensioner? Then I could eliminate the door jamb lever that always breaks?
Oldsmbl
36
13
I have bunches of these. Used. $10. Greg. Call or text me at 864-616-4619
Ribbedroof
4,951
7,133
Wellston, OK
You can get the belts re-webbed several places....and probably should due to age and sun exposure. I mean, racing belts have to recertified, and they live a much better life than un-garaged "old car" belts
Personally, I think the original belts are the best design ever. I love that you can pull it out to get a little slack and it will stay there. Should be added to "modern" seatbelts, IMO.
Rocket350
38
44
Charlevoix, MI
I agree with the pull and slack.The mechanism of the belts work great. I want to keep it factory.
