BUILD THREAD Sweet Johnny & Gina: A Love "Two Large" To Fail
78Delta88
1,307
1,095
SW Arizona
I figured that was better than haloing in. I'm not sure what crater would be made from a camshaft from 35,000 ft.
1104 would be the most you would want on a stock 305 with stock pistons, heads, and no headers. LSA is 114 so Still will be good with vacuum.
Just make sure break in with ZDDP, 1500 to 2000 for about 15 minutes, 8 to 12* before TDC. Then bump up to 14 once settled it. Port vac for distributor and will be nice even with stock weights and springs until you want to play with them later. Lift is only about .460 will be ok with for now until you can change springs.
Sweet_Johnny
Has A Face For Radio
676
1,230
Wichita, Kansas
Thank you very much sir! I had selected a cam that's slightly different with an LSA of 112 but the lift and duration numbers are pretty close to what I was looking at. I figured somewhere around 0.440-.460 with duration around 212-220: basically the old LT1 or L82 cam with a tighter LSA. I was actually eyeballing the Summit 1102 or 1103, and the Lunati 10120702 which are all very similar to what you selected.
78Delta88
1,307
1,095
SW Arizona
1102 is weak, doubt you would like it. 1103 I think is the 2 stage... Still weak
Sweet_Johnny
676
1,230
Wichita, Kansas
I like the way you think. I was trying to think conservatively which is brand new for me. That cam will be quite a nice change from the super weak lump that's in there now!
78Delta88
1,307
1,095
SW Arizona
Check the back yard or maybe the tree stuck in a chute. Careful might be trip wire to a grenade simulator, these QRF guys ... Have strange sense of humor...
Anyway... shows delivered on my end
Sweet_Johnny
676
1,230
Wichita, Kansas
Best news I've heard all day, maybe the grenades will scare away the moles.
78Delta88
1,307
1,095
SW Arizona
That's funny. Originally I had it as an artty simulator but changed it to grenade simulator.
Now hooking one to the XOs drive shaft of his humvee, nah I would never do that.
I think he needed a psychiatrist after he was around us for a week in the field.
