T56 differences. Is there any?
Built6spdMCSS
5,839
9,770
Florida Beach
I have looked up if there were any differences and really the only thing I am seeing is input and output shafte spline counts.
Both are 26 spline, the LS1 Fbody shaft is longer.
roger1
537
770
San Angelo, TX
They are rated by torque not horsepower.
I have a T56 Magnum in my '55 Bel Air. It's the wide ratio version. They've recently released a version of wide ratio with a little different ratios. The T56 Magnum is rated at 700 ft.lbs.
Built6spdMCSS
5,839
9,770
Florida Beach
Which is funny they say that because if you take the Fbody (adding in a Viper 2nd Gear), Corvette, or GTO T56, Shim the shafts to zero lash, and add the "Stage 2" Kit they are supposed to handle 750hp/tq.
The magnum has wider gears so that def helps.
roger1
537
770
San Angelo, TX
I really like the 2.97 first mine has in my Bel Air with 3.55 gears. I like the .50 6th too for a highway cruising gear for great mileage.
The newer Magnum wide keeps the 2.97 first but changes 6th to .63.
The close Magnum has similar gearing to the f body T56. 2.66 first and .63 6th.
88 Gutlass
102
249
Ga
I had a 96 t56 behind my 465h 500lbs 386 LT1 running 10’s Dumping the clutch a 6k on full slicks with no issues
Built6spdMCSS
5,839
9,770
Florida Beach
The Fbody has the 2.66 1st but with the .50 6th. You can change whatever you wanted though in 5&6 as long as you have the right parts
