I rarely post here (usually on MalibuRacing.com), but I thought I'd stop over with a few pics. I'm currently in the process of pulling the motor back out to do rings (drove it as a major smoker last summer ).
Motor is basically a Vortec 350 long block with a Comp XE268 cam (224º/230º @ .050", .477"/.480"), GMPP dual plane intake, and Edelbrock 1405 (600cfm) carb. I'm also replacing the Saginaw 3-speed with a 4-speed I picked up a couple weeks ago... finally found one with the ratio set I've been looking for It also has a set of Hotchkis springs, 34mm F-Body front sway bar, stock G-Body rear sway bar, and F-41 frame braces. This may be the last summer this car gets driven, I've been noticing little hints that the car is basically falling apart (dang rust belt...). I have a '78 that I picked up just after Christmas '07 that will ultimately have an LS motor and T56, but until I can afford that setup it will get a motor/trans (and the suspension) transplant from the '81.
The '78
The '78
