Transmission Temperatures
Ferret
Aug 31, 2012
82
6
Luxembourg
Hello everybody!
I need your input on the average temperatures of your automatic transmissions?
I run a TH400 equipped with a deep pan (cooling fins), stock lines going to the engine radiator, and a temperature sensor in the out-line of the transmission. The reading it gives is around 175°F - 210°F during the usual stop & go traffic madness. On the highway its around 160°F. The difference to the engine-temperature is minimal
Should I hook up an additional cooler or is the temperature still within acceptable range? I don't want to run the transmission to cool though (apparently this can happen on a TH400), but the ATF-viscosity is best at low temperatures, giving better shifts. I use Comma AQ3 and was told it would handle heat a lot better.
rccktmn2
196
Paulding Ohio
Trans temps should be close or at least comparable to your engine temps. If your running over 220-230 I would start to worry a little but it also depends on how you drive. A deeper pan with cooling fins running 160-210 is pretty normal. I never had a sensor in the line before I usually put it in the pan but either way it should be pretty close to the same
82GPLJ455
197
ma.
In my diesel performance days not long ago i ran a ford powerstroke with auto transmission pushing 500HP at the wheels.we did not run the radiator cooler(it actually voided the warranty on the performance trannies we were running),we ran the largest cooler we could get.normal transmission temps were considered to be 100° over outside air temps.if it was 80° outside 180° transmission temp was normal.
Alerch
285
171
Goose creek SC
My old duramax would run about 175* or so running down the interstate... hauling the gooseneck trailer it would get up to 220-230 on the back roads. I'd say that's nothing to worry about as long as the temps don't get excessive
Ferret
Aug 31, 2012
82
6
Luxembourg
Hmm, today it jumped for the first time to 240°F idling at the traffic lights. I guess now that the outside air temperatures are rising above 68°F the cooling effect of the stock radiator lessens. I think I will update to an external cooler, just to be on the safe side...
