Trunk lid torque rods
MadDrOlds
39
15
8
Haynes tells me the two rods behind the rear seat are to tension the trunk lid latches and you can adjust by prying from one notch to the next. Anybody know if the bottom setting is lightest effort or heaviest effort? I don’t want to mess with it if I’m already in the best setting.
Also, anyone just take them out? They kinda rattle and hit my aftermarket speakers. I should say I have a hurst spoiler on the back so the trunk lid is very heavy
69hurstolds
8,199
17,602
Take them out and your trunklid won't stay up at all by itself. The higher you go on the slots, the more tension (torsion) you put on the rods. Lowest is weakest, top it strongest. They don't always have to match slots on either side, but most of the time they do.
Supposedly, the H/O got bigger rods back there to make up for the added weight of the spoiler. I've never measured them for comparison, but that might be something to measure one day if I'm piddling around in the shop.
MadDrOlds
39
15
8
Thanks. I have an 85 442, but it came to me with the Hurst bits from an 84 (hood scoop, spoiler, front grills, lightning rods). It would be interesting to know if the hursts had bigger ones because that deck is way heavy. Somebody should make a carbon fiber replacement
69hurstolds
8,199
17,602
The 85 442 has the same trunk rods as every other Cutlass Supreme/Salon. Just so happens I have the 85 442 and the 84 H/O butt to butt in the shop so popping the trunk and doing a measurement on each shouldn't be too tough to do.
69hurstolds
8,199
17,602
OK, I'm back!
hahaha
I went to the shop for something else today and remembered I hadn't took trunk lid rod measurements. Well, I'll be durned, the H/O has fatter trunk rods than the regular trunk lids. Not by much, but it doesn't have to be. I measured both the 85 and 87 442 and got about the same measurements.
85 87 thickness breaking in at .324".
84 H/O trunklid rod thickness. There's the proof. A .357 magnum... :)
ck80
Moderator
Moderator
5,743
9,122
OK, I'm back!
hahaha
I wonder if that means the Monte SS and the Grand National got larger via their spoilers adding weight?
ELCAM
1,124
1,270
Looks like it. Any color markings on your torsion rods? Looks like tan is with spoiler and green is without.
565bbchevy
9,615
12,683
Michigan
I don't think it would be necessary for either since I have a GN rear spoiler on my Regal and a 2" taller Monte SS rear spoiler on my Monte CL and they both hold fine. I think both of those were very lightweight from the factory.
