Which S10 wheels fit without spacers?
Wageslave
1,750
3,342
On all 3 of the wagons I've put these on, I had to open up the center bore a little so they would fit over the hub pilot.
I have heard that it is about a 2mm difference, but well within the realm of a curved file.
Cauterize
Floater of Valves
515
1,550
Deathbridge
That works. But a flap sanding wheel in a drill or die grinder is far quicker and more uniform.
Just get one slightly larger than the hub bore.
Ribbedroof
4,930
7,073
Wellston, OK
I used a ridge reamer on mine....
CopperNick
3,396
3,069
Canada
Mine are the 15 inch alloy rims off my 03 S-10 and the only fitment issue was a little work to the centre hole to get it to index tightly; combination of corrosion and wear needed tweaking. Otherwise they fit fine and turn easily.
