Wilwood 4 piston vs Blazer front brakes
64nailhead
Goat Herder
Dec 1, 2014
5,710
12,219
Upstate NY
I'm looking for more front brake than the Blazer brakes I have currently. I'm considering buying a Wilwood kit :
but I'm curious if the Wilwood kit will be more brake than I have now. Before anyone says it, I intend to stick with the 15" Drag Lites and I know that a 17 or 18" front wheel would get me into C5/C6 option that would outperform both. But I'm stubborn, and the Drag Lites are more than Lite in name. They are crazy light weight and I need all of that help I can get.
melloelky
4,162
9,569
mass
on paper it looks like an upgrade,it's twice the #of pistons throwing down(abet 4 smaller than the two larger) than the blazer version that equals covering a larger area doing the squeezing.the spindle mod's easy btw.i orginally had these with a set of dropped spindles and ran into a track width change that was to much so i scrapped the whole set up.
64nailhead
Goat Herder
Dec 1, 2014
5,710
12,219
Upstate NY
melloelky What spindle mod are you referencing? If I decide to go with the Wilwood setup I was going to swap the G-body spindles back on and save or sell the Blazer spindles that are on the car presently.
melloelky
4,162
9,569
mass
you have to trim the o.e caliper mounting ears back and drill/tap the holes to another size to accommodate the new caliper brackets/hardware.the new brakes come with decent instructions you'll be fine.
