If you have a Chevy Small Block, what intakes clear the hood
V6UnderPressure
202
8
New Lenox, IL
I'm in the process of having a 383 Chevy Small block built for my cutlass. Not going LS, not going OLDS, so I'll save some of you the breath. :) I am retaining the stock hood and will not be going cowl. I have heard stories of the RPM air gap intakes being too high to allow the carb to clear the hood. What sort of intake manifolds are you running and how are the clearances? I'd prefer not to remove the hood paid. Thanks everyone in advance. I'd like to hear what you're running.
jociha
279
Re: If you have a Chevy Small Block, what intakes clear the
I have the Dart SBC dual plane air gap style with a quickfuel carb and 3.5in air cleaner just fits.
lilbowtie
3,460
3,965
Canton Mi
Vic Jr w/ 1" spacer
84cutspreme
1,146
152
I have a wieand 8150 high rise dual plane. Also have a 1.250" drop base and 3.063" tall filter
ssn696
Living in the Past
5,546
6,671
Permanent Temporary
Weiand Stealth midrise, basic Edelbrock tin air cleaner on a 1406 carb. See attached shot up through the fender. There's at least another inch up there to play with under my Malibu hood.
ssn696
V6UnderPressure
202
8
New Lenox, IL
Anyone out there that runs an air gap under their stock hood?
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
I do, it's an edelbrock and I run a 1" spacer under the carb with a drop air cleaner with a 3" filter
81Regal
1,557
485
83
Terril Iowa
I am with a drop base air cleaner, very close fit to the hood.
