PLEASE HELP ME IDENTIFY A 1987 442
farteaga92
46
8
I CAME ACROSS A 1987 CUTLASS 442 FOR DIRT CHEAP. (NEEDS RESTORED) BUT IT HAS A SUNROOF INSTEAD OF T-TOP. VIN#1g3gr119xhp311381 BLACK WITH SILVER BOTTOM AND GOLD WHEELS. HOW CAN I FURTHER ID ID THIS A REAL 442. ENGINE HAS THE CHROME CLEANER AND DUAL INLETS FOR AIR. HOW CAN I CHECK IF IT HAS THE ORIGINAL REAR AXEL AND transmission. THE GUY HAS THE ORIGINAL BUILD SHEET AND IS THE ONLY ONWER SINCE 1987. THIS SOUNDS TO GOOD TO BE TRUE SO IM SKEPTICAL IF HE IS TRYING TO SCAM ME..... PLEASE HELP.
gmparts
183
103
Look on the option code sticker in the trunk for option W42 and the 8th digit in the vin should be a 9
Good luck
farteaga92
46
8
heres some pics.
farteaga92
46
8
i guess i have to check for the 8.5 rear end and how can i check the engine code? or transmission code?
farteaga92
46
8
$1600 isn't bad right? it runs and drives. its just that I'm buying it a state over so i ill have to pay $200-$500 shipping fee since i don't have a trailer.
88hurstolds
1,749
660
The VIN proves it's a 442.
Check the VIN stamp pad on the block to verify that it matches the VIN on the cowl or look for a thick harmonic balancer and cast iron manifolds like a 350 would come with.
Check the trans tag for KZF and you can also check the VIN stamp on the drivers side.
The 8.5 is easy to ID, just check for square fangs below the cover, Google images can help aid in the ID.
Seems that if this is a one owner car everything should be original.
It's a very rare car with the CF5 sunroof option, if it were me I would restore back to stock instead of hacking it up with mods but to each is own...
farteaga92
46
8
where will the block stamp be located? and will it match the vin on driver side window? i wan to check all this out to verify is all original
88hurstolds
1,749
660
FYI this topic has been best like a dead horse on this board.
Search VIN and you'll have your answers...
The VIN pad is on the drivers side below the head ID 7A.
