Rear main seal 🤦🏽‍♂️ help please
Trapboss.Gbody
33
17
8
Oklahoma City, OK
After replacing both my valve cover gaskets, I found out my leak is coming from the rear main seal. This is so frustrating to me because I have put so much money into this car, and I feel like all these mechanics are scamming me for money. Gbody family I’m so pissed rn 🤦🏽‍♂️ if anybody see this and lives in Oklahoma City I would greatly appreciate your help please.
I NEED HELP WITH MY CUTLASS PLEASE
Thanks
Oct 14, 2008
8,826
7,779
Melville,Saskatchewan
What motor? How much is it leaking?
Trapboss.Gbody
33
17
8
Oklahoma City, OK
It’s the original 307 olds motor, and it’s not even leaking much but it leaves a couple drops everywhere it get parked at and I was tired of oil being everywhere especially in my garage 🤦🏽‍♂️ I was told it was my valve cover gaskets got them fixed now they are saying it’s the rear main seal.
SS_Malibu
1,172
2,059
Mesa, AZ
Are YOU sure it’s leaking from the rear main seal or is that what the mechanic told you? If you are unsure to believe him, clean the area underneath between the engine and trans check the back of the engine after driving it to see if oil is coming out. You may need to temporarily remove the torque converter cover to do this. 4 bolts.
I know it’s a bit of a pain but you’ll be learning and that’s a good thing.
SS_Malibu
1,172
2,059
Mesa, AZ
You posted just before I did. If it’s not leaking much and money is an issue, keep an eye on your oil level and put a drip pan in your garage. The leak just creates a mess on the bottom of your car.
8,826
7,779
Even removing the dust cover on the torque converter will allow you see if it dripping from the rear main. The back of the intake or the oil filter adapter are also possible leak spots. It is also possible the valve covers are still leaking.
DRIVEN
8,076
14,544
*CENSORED*
Don't automatically assume you're being scammed. It's standard procedure to attack oil leak repairs from the top down. That's how gravity works. You drive an old car and it more than likely leaks from more than one place. While it's entirely possible that your rear main seal is leaking, so could many other things back there. Clean everything and do your own diag before doing any repairs.
Reactions: 5 users
SS_Malibu
1,172
2,059
Mesa, AZ
Also check the oil sending unit. It is located at the top of the block behind the distributor. It could be dripping down the back of the engine.
Trapboss.Gbody
33
17
8
Oklahoma City, OK
I got down there an look at it myself guys, the leak it’s coming down and dropping from off my oil pan and some was on my pipe also. sh*t I even seen a little antifreeze leaking from the bottom of the motor also smh It’s not a lot of oil but I’m pretty sure it’s coming from that rear main. I even checked the valves and they were dry after the install and letting it run. I might as well prepaid myself to get ready to get a new motor faster then what I wanted 🤦🏽‍♂️
