Ok guys, this is kind of a crazy idea, but i think it'd work so i thought id run it by you all. Im going to be getting a 305 from a friend soon and i want to be able to run it, but since i dont have a car, ill need to make an engine test stand. I came up with this idea to make one out of this wood block that i have in my garage. Its about 16.5in wide, 27in long, and 5in high, so i think it would be big enough to mount an engine to. I was thinking of fabricating two brackets like the ones on the k-frame that id bolt directly to the wood block, and then to the motor mounts. Then i could just make some kind of bracket and mount a radiator to the front and just use the clutch fan to cool it, and since the fuel pump is cam driven, i can just run a fuel line from a little gas can to the pump. I made a lil diagram just to make the idea more clear 8) .
