I'm a mechanic by trade and do the occasional side job for the extra cash. This particular one is a 1995 Mastercraft with an LT1. The engine was "manufactured" by Indmar Marine. It appears to have many Corvette spec parts. Everything is painted black including the aluminum heads. I just have it for a water pump replacement, tune-up, oil change and winterization. Here's the stuff I thought you guys might want to see...
Speed density conversion
No Optispark! There is a reluctor wheel on the front and a crank sensor on the timing cover.
The ignition system appears to be all GM. Northstar or Aurora maybe?
The ECM is mounted to the back of the engine and is about the size of my hand. Can't see any part numbers or manufacturer markings. I assume they're on the back.
For you guys looking to do swaps this may be another source for parts or ideas. It's also an interesting way to delete the Optispark. Feel free to chime in if you have any more info on this or similar setups.
![003-36.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi283.photobucket.com%2Falbums%2Fkk302%2Fmistervelocity%2F003-36.jpg&hash=84bae040d9aed6a3ce8b5c576cf2a947)
![004-27.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi283.photobucket.com%2Falbums%2Fkk302%2Fmistervelocity%2F004-27.jpg&hash=deaa1c1da8e558ce7fc5de2a382999d4)
![005-21.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi283.photobucket.com%2Falbums%2Fkk302%2Fmistervelocity%2F005-21.jpg&hash=4010614a51a5df294994cdafdc91dcc3)
![006-20.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi283.photobucket.com%2Falbums%2Fkk302%2Fmistervelocity%2F006-20.jpg&hash=db79ea39e712337a5b29a360bd58d86b)
![007-14.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi283.photobucket.com%2Falbums%2Fkk302%2Fmistervelocity%2F007-14.jpg&hash=9fbe635d458407b6de770ed5b8b97785)
