The largest community of 1978-1988 General Motors G-Body cars. Chevrolet Malibu, El Camino, Monte Carlo; Oldsmobile Cutlass, 442, Hurst/Olds; Buick Regal, Century, T-Type, Grand National; Pontiac Grand Am, Grand Prix, LeMans, Bonneville; GMC Caballero
GBodyForum Supporting Vendor
reverse/neutral safety switch wiring
Tech articles etc. for Electrical and Interior issues.
User avatar
krazykyle
G Body Guru
Postby krazykyle on Sun Apr 25, 2010 8:58 pm
i just installed a Hurst pro racket shifter,it has a reverse and separate neutral safety.does anyone know off hand which wires i need to splice into for the reverse lights and the neutral safety?
User avatar
84cutspreme
Re: reverse/neutral safety switch wiring
Postby 84cutspreme on Sun Apr 25, 2010 9:24 pm
The reverse lights in my 84 cutlass worked off of the blue wire going into the neutral safety switch. Just make sure you get the wire input before it goes into the current switch. I just ran micro switches for my 700r-4 to get reverse lights and park-lock. If you need to do park-lock just tap into the purple wire where it runs between the ignition and starter. I can probably get you a pic of the schematic if you need it since I only did reverse lights and park-lock, no neutral-lock.
User avatar
Blake442
Postby Blake442 on Mon Apr 26, 2010 2:01 am
If you left the linkage from the trans to the column intact, you don't need to wire anything, and the cars original functions can be retained.
'85 Oldsmobile 442--Olds 455-TH400
'83 Oldsmobile Cutlass Cruiser--Chevy 350-TH350
Past G's--'81 Regal, '84 El Camino, '79 Cutlass Supreme, '87 Cutlass Salon,
'81 Monte Carlo, '81 El Camino, '79 Malibu Wagon, '81 Century Estate Wagon
User avatar
krazykyle
G Body Guru
Postby krazykyle on Mon Apr 26, 2010 6:33 am
well i do have it hooked up with the original linkage for the car.i have a manual shift valve body and i just thought with all the shifting i will be doing that linkage might be a burden.it's not the tightest linkage around either and since the shifter came with the switches i thought i would use them.
User avatar
454muscle
Postby 454muscle on Mon Apr 26, 2010 7:18 am
In my previous 84 GP it was a green wire in a straight-line harness near the fuse box near the bottom left, under the dash.
Easy way to figure it out: Look in your trunk, find the main bunch of wires (usually along the left side of the trunk) and mark down the colors in that bunch and the order of them (as they run into the harness, which is near the left corner of the trunk). One of those wires is for reverse lights.
Now go under your dash and look for the same bunch of wires (same colors) as they go into a harness. Grab a test light, connect ground and use it to find which one of those wires lights up your reverse lights. Tap into it with your new switch's power wire. Done.
Ricers can't scare others by just idling.
"...back in the day, if you opened the hood and it didn't have a big block, it was your mother's car." - Pat Musi
Former G-body Of The Month winner.
Project RAWDOGG: 1984 Pontiac Grand Prix Pro Touring
Build Thread | Stolen Thread | Cardomain | Youtube | "The G-BODY Poem"
'84 Pontiac Grand Prix T-top, Edelbrock 555 BBC EFI crate motor, TCI Superstreetfighter 4L80E, Currie "Detroit Locker" rear w/3:89 gears, Ridetech Street Challenge air ride kit, Flowmaster Super40s, Custom body kit, Black leather heated power bucket seats, Power Mirrors, Custom dash bezel, Autometer Cobalt gauges, G-tech Pro EGS tach, Dakota Digital Climate Control with AC by Vintage Air, B&M Megashifter, Custom center console, MB Quart components, Rockford Fosgate T2 subs, Night Rider nav GPS unit, switches...
User avatar
krazykyle
G Body Guru
Postby krazykyle on Tue Apr 27, 2010 9:38 am
sure if you have a diagram it would be helpful
User avatar
joe_padavano
Postby joe_padavano on Tue Apr 27, 2010 9:56 am
krazykyle wrote:sure if you have a diagram it would be helpful
Well, you could always BUY a factory service manual...
In any case, G-body cars do not have an electric neutral safety switch. They have a mechanical interlock in the steering column. If you have disconnected the backdrive linkage to the column, this interlock will not function and you will be able to start the car in any gear. The switch on the column is for the backup lights and a park/neutral signal to the computer. It is NOT connected to the starting circuit.
Joe Padavano
64 Jetstar 88
66 442 conv
68 W-30
69 H/O
69 442
70 W-30
72 442
78 Camino
86 Caprice SW (w/307)
User avatar
krazykyle
G Body Guru
Postby krazykyle on Tue Apr 27, 2010 11:30 am
I have two manuals and the one just shows the picture of the safety switch,i can't seem to find the wiring diagram
User avatar
84cutspreme
Postby 84cutspreme on Tue Apr 27, 2010 11:31 am
Like I said before interrupt it before the switch where it is blue.
...just to comment on all the nit pickers, It is called the gear selector switch...but it does basically the same thing as a neutral safety. Only allows starting in park & neutral, and activates reverse lights.
User avatar
krazykyle
G Body Guru
Postby krazykyle on Tue Apr 27, 2010 11:45 am
thanks man i can't seem to find that page.is that in the chassis manual or the electric manual
Next
Return to Electrical and Interior
Who is online
Users browsing this forum: No registered users
