GBodyForum Supporting Vendor
Rack and Pinion in a G body
tetomas
Postby tetomas on Sun Dec 02, 2012 8:14 am
Anybody put r+p steering in a g body? I am doing an LS1 swap in my 80 camino, my donor car is a 2002 SS camaro, I got the whole car so I started thinking about other parts I could put on my car. There can be some interference between the steering shaft and the drivers side header, so why not re-route the shaft to a different steering gear? Anybody done it? Will it work? Do you think it is a worthwile swap?
Jimmy
Life is tough, Life is tougher when you are stupid
80 ElCamino in progress 5.7 liter LS-1 4L60E 3.73 Auburn posi should be fun to drive
User avatar
pontiacgp
Re: Rack and Pinion in a G body
Postby pontiacgp on Sun Dec 02, 2012 9:25 am
It's been done but besides the weight save you end up with other problems. If you want you can get a box that has been lightened and weights 8 lbs less than a stock box. We use it on our sportsman car
jlcustomz
G Body Guru
Postby jlcustomz on Sun Dec 02, 2012 5:09 pm
I,ve been checking into it for years now,doesn't seem to be the way to go for our applications. As stated---other problems. The best autocross cars & suppliers seem to just use upgraded steering boxes & components.
No true hot rod is ever finished. If it doesn't command respect, fear will do.
http://s1094.beta.photobucket.com/user/ ... 2720766585
http://www.youtube.com/watch?v=n3mL8ze7 ... ature=plcp
Mystery_man
Postby Mystery_man on Thu Dec 06, 2012 9:50 pm
Is there any links to those that have done it? What type of issues are they having?
I would really like to put a rack in my car also.
1 weight savings
2 newer tech
3 more gear ratios that can be used for tuning
I just to see what the issue would be with putting a rack on an older car.
User avatar
pontiacgp
Postby pontiacgp on Thu Dec 06, 2012 9:55 pm
User avatar
CWPottenger
Postby CWPottenger on Thu Dec 06, 2012 10:47 pm
Mystery_man
Postby Mystery_man on Thu Dec 06, 2012 11:06 pm
Ok so the only issue I have seen was the ratio of the pinto rack. I can do google searchs just fine. I didn't use the same verbage as you did. I am just wanting to know what the issues that you have seen or been told of. I saw some people liked the s-10 manual box over the TRZ/pinto rack.
That kit is the TRZ kit just 249 more dollars than what you would pay buying it from TRZ.
Mystery_man
Postby Mystery_man on Sun Dec 09, 2012 4:23 pm
Ok got some more info. The pinto is 3.75 lock to lock and the mustang 2 is 3.25 lock to lock. The foxbody has a power rack that is 2.25 lock to lock which would be worth a swap and you can have a power rack. Just have to fab up a mount for the fox pump and belt size will have to be found that works.
Mystery_man
Postby Mystery_man on Thu Dec 27, 2012 8:13 am
So no one wants to discuss this or give any info on putting a rack and pinion in these g bodies.
Free Shipping on Orders Over $75!
User avatar
JBreu
Postby JBreu on Thu Dec 27, 2012 9:23 am
Mystery_man wrote:So no one wants to discuss this or give any info on putting a rack and pinion in these g bodies.
Why would you want to is the question I guess....I went with the S-10 manual box, freed up some HP and lost some weight...Easy swap and on the cheap to 8)
1984 Monte Carlo with sbc 388 stroker ( dynoed 514hp) 700-r4 , 12 Bolt w/4:10
Old Chevy's Don't Die, They just get faster!
Best ET to date : 12.20 @110 Mph All Motor
Next
Return to Chevrolet El Camino / GMC Caballero
Who is online
Users browsing this forum: Majestic-12 [Bot]
