qa1 colover kit?
boblem73
11
Roseville, Michigan
I am looking at installing a coil over kit in the front of my 83 Buick Regal. I am wondering if anyone has had any good or bad things to say about it? If I do put one in what spring rate should I get ...350 or 450?
87PearlRegal
14
Dayton, Oh
I noticed nobody replied to your post. I was looking at the same kit probably from Spohn.net. I'm talking about the 18 way single adjustable set.
baddog
5
i put one on my 86 regal. i called qa1 and they said if you use a small block use the 350 spring and if you have a bb use the 450 spring. they install pretty easily. i have not put my big block in yet, so i don't now how it's going to set, but theres plenty of adjustment.
Chris Van
515
4
16
Middle Ga.
Hey boblem, I know this has nothing to do with the question you asked but judging from the pic in your avatar you will benefit WAAY more from an anti-roll bar than front coilovers....LOL
Seriously though.... I've seen a few cars with the front coilovers and it is a sweet setup. I'd like to have a set myself but they are just not in the budget right now. And like someone else stated, go with the 350's if you are running a small block.
FE3X CLONE
2,714
47
48
Ohio
If you want something more for handling, go with the 550 springs.
billcox
27
What rear spring rate would you suggest for handling? My car has a big block and a 7.5 with a posi unit in it?
XCESSIV6
Apr 5, 2012
74
6
Cincinnati Ohio
I have been running the coil over system with BMR upper and lower control arms for 7 years I used the big block springs.
The reason I went with them is I wanted the car to handle and I have big front mount intercooler. If your not going to go with a high performance tire, I'd go with the small block spring if you are looking for a softer ride.
XCESSIV6
Apr 5, 2012
74
6
Cincinnati Ohio
PICS
FE3X CLONE
2,714
47
48
Ohio
Kind of depends on the rest of your suspension setup but you'd likely want something in the 150-160lb/in range to match a front spring rate in the 500-600 range.
