G body regal
Someone_Much_Cooler
116
Are the rear aluminum inner bumpers interchange able between g body models?
Can I convert to the s10 manual steering with a grand national? Is it recommended?
Blake442
6,866
2,011
Minneapolis
No. If they came off a Regal, they will only fit a Regal.
Yes, you can do that swap on any G-body. As for if it is recommended, I wouldn't.
The HydroBoost brakes on the Grand National are run off of hydraulic pressure supplied by the power steering pump.
So in addition to the extra steering effort to save just a couple horsepower, you would also have to covert the brakes to either manual, or a traditional vacuum booster set-up. Sounds like an awful lot of work for such a small gain.
canadiantbone
Feb 20, 2011
62
2
British Columbia
the s10 manual box will fit into the regal. I have one if you are interested.
custom442
1,889
4
Houston
depends on what you plan to do with the rear clip. If you want a stock rear, then no
stomis
403
Brick NJ
I thought that the Cutlass and Regal were the same base body. w/ different *ss and front clips?
joe_padavano
1,151
13
Northern VA
I'm not a GN expert, but my friend's all original 86 GN has a factory-installed Powermaster brake system. The hydraulic booster is self-contained and uses a small electric motor to provide the hydraulic pressure for the booster, not the PS pump. In fact, the Powermaster uses brake fluid for the booster working fluid, not PS fluid.
Blake442
6,866
2,011
Minneapolis
The only things that the Cutlass and Regal share is the doors. Everything else is different.
Blake442
6,866
2,011
Minneapolis
Joe, I think we're both right, as there are two different set-ups that were used on the GN's.
The earlier hydroboost, and the later powermaster.
Either way, for the subject at hand, it doesn't matter since this guys car already has vacuum brakes on it.
