GBodyForum Supporting Vendor
700R4 swap?
Stuff like brakes, frame, springs/shocks, tranny's, etc. etc.
User avatar
Camshaft
G Body Guru
700R4 swap?
Postby Camshaft on Thu Jun 18, 2009 9:45 pm
I've found a 700R4 locally, and I'd like to rebuild it and swap it into my '86 Cutlass. It's a column shift car, will everything bolt up and work when I'm done? I plan on swapping for the rally gauge cluster later on.
1986 Oldsmobile Cutlass Supreme Brougham - triple green, 307 V8, 87,000 miles
gotmonte
Postby gotmonte on Thu Jun 18, 2009 10:24 pm
I am doing a 700r4 swap into my 85 monte right now. Only thing I see as a problem is the cross member being different.
As for column shift, I am unsure. I am using a B&M shifter on the floor
'85 Monte Carlo: 355ci/Th350/12 Bolt, 4.56 gears.
'01 Camaro SS: 408 ci/Th350/4000 stall/moser 12 bolt 4.10..SOLD
'69 Camaro Z28: ZZ4 350ci/Th350/3200 stall/3.73 gears.. SOLD
User avatar
jrm81bu
Re: 700R4 swap?
Postby jrm81bu on Thu Jun 18, 2009 10:38 pm
Camshaft wrote:I've found a 700R4 locally, and I'd like to rebuild it and swap it into my '86 Cutlass. It's a column shift car, will everything bolt up and work when I'm done? I plan on swapping for the rally gauge cluster later on.
Are you still using the 307? Does the 700r4 have the correct bellhousing bolt pattern? Was the car originally an overdrive car? You will have to get a different crossmember(or modify it) and have your driveshaft shortened.
81 Malibu
400(350 for now) 142 supercharger
700r4
3.73 posi 7.5
flip66
Postby flip66 on Fri Jun 19, 2009 2:26 pm
Do you have 200r4 now if so just wondering why you want to swap. There is a grate debate over which is better the 700 or the 200 but most racers like the 200r4 better
User avatar
megaladon6
Postby megaladon6 on Fri Jun 19, 2009 3:02 pm
flip66 wrote:Do you have 200r4 now if so just wondering why you want to swap. There is a grate debate over which is better the 700 or the 200 but most racers like the 200r4 better
x2 the later 700's are slightly more reliable stock, than the early 200-4r's but they are pretty even with the later 200's. and once they are modified the 200 actually has fewer problems. plus it has better overall gear ratios, and i believe it's lighter.
i've said before that the only real advantage to the 700 is that it's a direct swap for the 4l60E series which is a really good trans, especially the 4l65 and 4l70 models.(the 4LXX series also uses computer controls and as such can be programmed for exactly how you want it and you can install a true paddle shift system)
87 monte ss t-top 200-4r trans. 383ci 4-bolt, 9.7: hypereutectics, forged rods, vortec heads, xe274 cam, Q-Jet-home modified, Evans NPG+ coolant
User avatar
mugzi
Postby mugzi on Sat Jun 20, 2009 10:33 am
doing a swap my self in a 85 grandprix that came with a 200r4. my biggest problem is getting this drive shaft cut...anyone know the exact measurment
350 sbc / 200r4. headers, dual exaust...under waitin a mild cam..double roll timing chain, edlebrock intake, digital ignition...
413Cutlass
Postby 413Cutlass on Sat Jun 20, 2009 10:39 am
Don't forget the 200-4rs are BOP and Chevy compatable.
700s are chevy only.
88 Cutlass
307
3:73s
de-comped
a/c delete
catback
84 Bonneville
3.8
stock
(wifeys car)
83cut350chev
G Body Guru
Postby 83cut350chev on Sat Jun 20, 2009 12:07 pm
the crossmembers a little different, you'll need to cut ur driveshaft about 3 inches, and with column shift we had to make a metal piece to shift down into the low gears cause they wouldnt reach, nothing to serious. 700s are reliable if built right
83 Supreme Brougham,350 sbC,Built 700r4,Flowtech longtubes,2.5"pypes exhaust,650 holley/edelbrock performer rpm,MSD Hei,8.5 incher w. 3.73s,2" drop,front and rear sway bars, poly bushings ..
Free Shipping on Orders Over $75!
gotmonte
Postby gotmonte on Sun Jun 21, 2009 5:13 pm
I had a th350 with a 355 in the car originally when I bought it.
Went over to a 406ci so I got the 700R4 with the deal for the motor (for free).
So, I just modified the crossmember that was being used for the th350 and I have to have the driveshaft cut about 2 inches.
Ill know more tomorrow about the driveshaft. I had to get a different tailshaft out of a cadillac since the trans was out of a built iroc
Return to Chassis / Drivetrain / Suspension / Wheels
Who is online
Users browsing this forum: Caper10, pencero, Yav8
