Ford 9" sway bar options
Dugan
144
16
What kind of cheap options would I have for a 84 Monte with a 9" for a rear sway. Would any factory bars work?
prolly not, but i think h&r parts and stuff might have something for ya. also check out the vendors here on the forum...
I beleive the factory sway bar will work fine as long as you are using factory control arms in the right position, such as a bolt in 9" from Moser, Quick Performance, etc.
Here's a picture of Spohn's direct replacement bar on a 9" in a G-body
The factory bar from a 78 Monte fit mine with no problems. I’m using axel brackets off of E Bay and boxed the set of stock lower control arms.
Now how do these attach to the lcas. I've seen a few things but look after market. Does it come through bottom of them or mount out The side
I have a Hellwig rear bar on now but before that I had my factory F41 rear bar and I'm using Hotckis lowers. Both bars clear the 9" with no problems and work with lca's with factory sway bar mounting provisions which are mounted from the insides of the contol arms.The picture is with the factory sway bar.The Hellwig looks the same just bigger.
