mclellan83
4,326
9,678
Pgh, PA
Ahh. Well I do know that rear main seal cover was prone to porosity issues that would lead to leakage. I wonder if your little pocket bearing didn't leave the chat inside the trans? That's an awful lot of input slop, too much to be chalked up to improper shimming.
Oh yeah, those pieces of metal are from that bearing. My question is what happened to the roller parts of the bearing
Shoulder Shrug Idk GIF by MOODMAN
Supercharged111
4,968
7,782
Colorado Springs, CO
I think you're referring to the pilot bearing, I'm talking about the bearing inside the trans that supports the main shaft inside the input shaft.
mclellan83
4,326
9,678
Pgh, PA
Yeah you are right. I ordered the shim kit, input shaft bearing/race, and the input shaft seal assuming that they are bad in there
6,040
12,840
My younger sister had an accident in her Hyundai Accent and insurance didn't cover it, so I've been working on it in the garage over the last couple weeks.
Between several junkyards, I found a color matched fender and door, got a junkyard headlight, wheel and hubcap. I repaired the bumper cover and the tire was still okay. The strut was bent, so I replaced both front struts with new Carquest ones. I ordered new inner and outer tie rods from RockAuto.
I noticed a strong fuel smell from the car while it was in the garage, so I inspected that issue, and saw the fuel tank was rusted and leaking at one of the seams. I got it removed (it was 110% full of gas, BTW), and I'm going to pick up a salvage tank tomorrow.
While I was underneath inspecting the tank, I noticed the rear brakes were looking really rough, so I ordered new pads and rotors from RockAuto. At this point, the body work is done, I painted the replacement wheel today, so I'll have the tire mounted tomorrow and pick up a replacement fuel tank. Then I'm just waiting on RockAuto for tie rods and brakes. It pains me because I know she's not gonna take care of it, but it'll be right at least once when it leaves here.
Reactions: 7 users
86LK
2,013
2,071
1.6 GDI engine. those things will run forever. had an 04 and a 13, cheap to operate cheap to fix. (y)
Nov 4, 2012
6,040
12,840
I generally consider Hyundais to be disposable but it has been relatively reliable, especially considering she does absolutely nothing to take care of it.
Hurricane77
334
678
Ottawa, Canada
Hyundai stepped up their game in the last 15 years or so. Certainly not the same company as they were in the 90's and early 2000's
9,251
15,626
I remember when they were just better than a Yugo but the '07 Santa Fe we had for 12 years changed my mind. Only issues was those self wearing fuel tank senders I had to replace but they had access ports on the floor for that & the front sub frame starting to rot at the driver front mount. Her current '17 Santa Fe Sport has been good so far since we got it on the summer of '20.
