Boost Lee
CopperNick
3,419
3,107
Canada
This is probably a case of unlocking the gate after the goats have left but there is a product called Q-Bond that comes as an adhesive plus filler powders. I have used this myself and it does pretty much what the PR says it will do in terms of repairing and re-inforcing damaged components. For your old header panel, if you still have the damaged or broken off bits, this stuff ought to be able to bond them back together. With the powder, you can tape a hole shut from one side and then start to close the hole from the other side by alternating thin layers of powder with thin layers of adhesive. The bonder kicks off almost immediately and does generate heat in the process. My next thing to do with this stuff is to repair a couple of holes in the dashboard fascia in my van to restore them back to the correct diameter. Label on the box says Q-bond USA, Paterson NJ, and they have a website for more info.
Supercharged111
4,979
7,801
Colorado Springs, CO
Got some wiring done. Installed my new engine wiring harness and headlight harness. My headlight harness now just turns on relays. Not much of a milestone but it's the first time the lights have been on and windows powered down in 10 years. View attachment 206314 View attachment 206313
Kinda sorta.
Rt Jam
611
610
Ontario Canada
Boost Lee got a new Spectra fuel tank and a Racetronix dual fuel pump.
Rt Jam
611
610
Ontario Canada
Temporary wheel. The original 15" GN steel wheel would not fit over the disc brake caliper.
DSPbuilt
575
1,570
Cape Coral, FL
Hows the quality? I have there stock style upgraded version and was considering this when I go turbo
Rt Jam
611
610
Ontario Canada
DSP. I replied to your question in the gas tank thread.
Rt Jam
611
610
Ontario Canada
All new 11" drums for the rear.
