Driveshaft orientation
Drkuhar
515
919
Girard, IL
My driveshaft had the original u joints held in with the nylon that needed heating up to come apart. After doing that and seperating everything i set it to the side and didnt mark which end the yoke came off of.
So now its days later a i have no clue which end to put the yoke on. New u joints with inside clips but not together yet. Does it matter for balancing purposes. I thought the end with the weight on the tube went to the axle but not sure
spongbob
140
82
The Poster here( off site) days the middle ones off a el Camino if it's right then the smaller end goes to the rear ...someone else got a better pic
Drkuhar
515
919
Girard, IL
If the middle is an elcamino then the first would be what i have. A straight shaft with no reduction and it looks lile the weight is on the slip yoke end. Thanks for the pic
Drkuhar
515
919
Girard, IL
Not sure if your drive shaft has/had the painted stripes but those are painted closer to the transmission end.
Its so rusted cant see them
I may be making it big deal about nothing but it's my fault I let it set apart too long without marking anything
