Equipping a G-Body with a manual trans
10,610
14,407
I agree with Pontiacgp. You can't guess, you must mount the trans and see where the shifter wants to hit the tunnel. Mark it, and cut a small hole at first. Then you can enlarge it as needed. As you work the shifter, you will see where it hits and where to cut more. In my pic, you see a HUGE hole at the rear, because I had previously welded the hump to the tunnel and had to cut the whole mess out.
mebe007
1,808
4
36
newport news, viginia
So can I do a mock up with the engine out or do i need to install motor and trans, cut a small hole and install shfter and trim as needed?
10,610
14,407
That's the best way, the way it will sit when actually in use. Last time I did it I used a bare short block, bellhousing, and an empty trans case. I positioned the motor mounts, trans mount, and shifter hole all at the same time.
RocketGremlin455
38
6
Galloway NJ
OK. So I should be able to run some type of stick overdrive trans behind a 455 in an 87 Cutlass then. I have a set of 79 malibu pedals for it. I was aiming towards some sort of hydraulic setup...either clutch and slave or a hydraulic throwout bearing. Would linkage be easier to run? I'm probably going to try and obtain the W Z manifolds for space (if I can find them) and I rather not fork out the $600 for those over the frame swap headers. I have a nicely done 462 in my 73 (that I'm about to part out and junk) to use for a motor.
So the questions I ponder are.. Which trans would be easiest to work with....preferably something off ebay or a local sale. What bellhousing options would I have to work with. Then above all.. putting the right bell, trans, linkage, etc together as a paper checklist so I can start collecting parts. Standard parts from like Autozone or the like would be nice. I have no welder to do the whole F body pedal conversion.
I read every inch of John Bzdel's site, Mcleod's site, 442.com, etc. This will be my 4th 455 to Gbody transplant, but my first STICK in 1 that wasn't factory. Thanks for listening.
Doober
1,253
20
38
Swartz Creek, MI/Tucson, AZ
I don't know if the mechanical setup will work with a 455, a hydraulic throwout bearing would take care of any clearance issues, you'll probably have to get an aftermarket bellhousing too unless you can find one from another car (BOP bellhousings are even more rare than the Chevy ones).
CGimbel
36
6
Brian, pm sent.
It's been some years.
I have all the parts and information you need.
I'm back by five-points again.
