Fastener Resources
ssn696
Living in the Past
5,556
6,717
Permanent Temporary
Please make this a sticky. I just remembered a company called AuVeCo. They sell the exact hardware that the OEMs use. Their catalog is a bit of an adventure to find anything, but many of those hard-to-find trim clips are in here:
http://www.auveco.com/OnlineCatalog/index.html
Here are some handy references from the back of the catalog:
Reactions: 9 users
ssn696
Living in the Past
5,556
6,717
Permanent Temporary
9,636
12,768
I deal with a place called Motor City Fasteners in Hazel Park ,MI and they can get everything in the Au-ve-co catalog plus I usually get all my grade 8 fasteners there.
ssn696
Living in the Past
5,556
6,717
Permanent Temporary
Body bolts:
M10 x 1.50, grade 10.9, cap screw, black oxide,
(98093A648) 2 x 60mm (under driver) location 3
(98093A642) 8 x 90mm location 2, 4, 6, 7
(98093A652) 2 x 100mm (radiator support) location 1
Zinc Plated Class10 Steel Flange Nut,
(95003A103) M10X1.5 Thread, 21.8MM Flange Diameter, 10MM hole (radiator support)
Zinc-Plated Steel Oversized Flat Washer,
(91100A170) , M10 Screw Size, 10.5MM ID, 30.0MM OD (for shimming)
Corrosion-Resistant Coated Class 10.9 Steel Flat Washer,
(91455A450) M10 Screw Size (radiator support and shimming)
McMaster-Carr part numbers.
http://www.mcmaster.com
ssn696
Living in the Past
5,556
6,717
Permanent Temporary
Control arm bolts:
front:
M12 x 1.75, grade 10.9, Zinc Yellow Plated Steel Hex Head Cap Screw
2 x 110mm (95327A712)
6 x 100mm (95327A708)
Zinc-Plated Class 8 High-Strength Steel Flat Washer, 24MM OD, 2.3MM-2.7MM Thick
16 x M12 Screw Size (91455A150)
Zinc-Plated Class 8 Steel Conical-Top Hex Locknut, , 19MM Width, 12MM Height
8 x M12 Screw Size, 1.75MM Pitch (93795A250)
rear:
8 x 100mm (95327A708)Zinc-Plated Class 8 High-Strength Steel Flat Washer, 24MM OD, 2.3MM-2.7MM Thick
GP403
Administrator
Site Admin
Feb 25, 2005
4,515
4,940
Rolla, MO
stickied! kind of stuff that's good to know, or at least we know where we can come back to and find it now.
10,599
14,379
I try and replace corroded fasteners with stainless steel whenever possible. These guys have a huge selection. I especially like the ARP stainless line- it's very strong grade of stainless, like grade 8 they claim. http://www.allensfasteners.com/default.asp
ssn696
Living in the Past
5,556
6,717
Permanent Temporary
From HAFROD: "I went to my local auto upholstery shop and bought a box of 50 lower door panel plastic trim clips. They are in a green box with white lettering. The brand is Au-ve-co Products. Part # 11796. I paid just under $10."
