For those with Holley swap kit, how close is the rear coil to the AC box?
V6UnderPressure
202
New Lenox, IL
I would prefer someone who swapped a cutlass, but would like to hear experiences with other models as well. I've heard of the rear coilpack needing to be relocated. Why is this? Is the wire connection too close to the AC box? Is the coil bracket too close to the AC box? I may be moving the engine slightly forward for another issue but wondering if moving it forward would also help with coil clearance there.
Fatboy
44
45
Arizona
I am interested in this also.
Rocknrod
All Around Good Egg
97
87
I downloaded a pic of a 6.0 LS engine in a 85 Cutlass and see that the coilpaks are not relocated.
V6UnderPressure
202
New Lenox, IL
I actually just ended up going with the dirty dingo mounts and gforce gen 2 crossmember & adjustable trans mount. Everything else is Holley (accessory drive, manifolds, exhaust, etc.) and is very close alignment wise. I like the adjustability to move the engine forward a little. Plus the gforce gen 2 crossmember is a way better design than the Hooker crossmember.
Adam 442
n00b
Aug 18, 2023
4
5
I used the holley swap system and had had to relocate that one coil. It was hitting the ac box. I ended up moving it closer to the next coil by cutting the bracket.
doood
Amateur Mechanic
Sep 24, 2020
620
863
I had to modify the coil pack bracket to clear the air box on my heat-only 1984 Monte Carlo; my NGK spark plug wires are rather long compared to the OEM and could accommodate the longer distance to the plug. If I were doing it again, I would have welded two factory steel coil racks together in a similar manner. There are lots of pretty coil brackets to choose from (ICT billet, ebay, etc.), but they can be expensive.
The holley swap kit doesn't leave much room between the passenger head and the firewall, but this placement allows the truck accessory bracket power steering pump pully to clear the steering box. Holley claims their mounts put the bell housing in the same location as the factory original motors (SBO/SBC/v6), but you still need to get the driveshaft shortened if you are using a computer transmission like 4L60e/4L80e.
I was not happy with the Holley transmission crossmember, and the blackheart exhaust kit has been difficult. Some pieces were manufactured wrong (flared on wrong end) and it took weeks for Holley to make it right. I'm happy with it now after having it apart half a dozen times.
doood
Amateur Mechanic
Sep 24, 2020
620
863
That looks fan-frickin-tastic. Working AC and all! I used same transmission dipstick. What is the electrical box near the brake lines?
dgmeadows
187
561
Georgia
My car has the Holley mounts and 6.0 LQ9 block. I wanted to relocate the coils just because I liked the look better. I ordered low profile valve covers, black with polished ribs, but the ribs make them thicker than the stock covers. Had to do a small notch in the heater box, but it was easily sealed from inside. The oem valve covers are usually very low profile, so you might get by with no contact, and the coil may sit far enough forward to be out of the way.
