Gear Ratio/Speedo Gear table
ELCAM
1,132
1,284
A parts illustrated has this.
1984 Chevy.
8,835
7,800
Melville,Saskatchewan
TCI has one.
justacruzr2
151
144
Midlothian, Illinois
Thanks but I'm not sure how to use it. What I do know is that the car has P195 75R14 tires, TH350C trans and 2.41 axle ratio (code 2AJ from the build sheet). The speedo gear came from the car that was the donor for this project and it had same tires, TH250C trans and 2.29 axle ratio (code 2AH from the build sheet). It feels like the car is going faster than the speedo says but I could be wrong. The difference between the 2 axle ratios is only .12 and seems like a very small difference.
78Delta88
1,303
1,096
SW Arizona
Old school method. Get on the highway. Set speed to 60MPH. As you get to a mile marker, start your stop watch.
As you get to next mile marker, click stopwatch to stop it. Read result.
Less than 60 sec, you are faster.
More than 60 sec, you are slower.
60 MPH is one mile per minute (60 Sec).
