I don't think the Jeep pitman arm is the same length and angle. Of course, you'd have to compare it to a G-body 800 series pitman arm. What's in your car currently? It's either an 800 series or a Saginaw 604. The 604 pitman arm will not interchange with the 800 arm. Therefore can't be used on an 800 box.Thanks, I’ll check out the lock to lock.
I have the pitman arm that came on the box. Will it work or do I need to get something else? If so, what?
I just picked up a steering box from a 96 Jeep Grand Cherokee. What are the identification marks on the box that will indicate it is a close ratio? I plan on installing it on my 80 Malibu.
