exhaust for my 350 el camino
jcelk
328
241
I;m replacing a 3.8 chevy with a 350 engine with straight plug heads and a 350 trans in a 82 elky I'm in need of some advice for the exhaust. pipes and headers anyone know what will work shorty headers are ok with me not a hp engine maybe something i don;t have to spend the whole ss cheak on thanks for any input
Full length headers make the most power across the board, shorties are barely better than manifolds, and mid length are a decent upgrade with lots of clearance. Tri-y headers make excellent torque in a "street" powerband and are great for tow trucks etc.. A header flange needs to be thick so it doesn't warp so try to find ones that are 3/8" thick, no thinner than 5/16". For a 350 you'll want 1.5" primaries for a low performance cam/ heads, 1 5/8" for most setups, and 1 3/4" for a TPI or highly modified 350. For pipes you'll probably want 2 1/4" diameter but 2.5" is the most common and is alright for almost every 350 (just not perfect). Ball and socket header collectors are great- they hardly ever leak and don't require a gasket, 3 bolt flat collectors are most common, 4 bolt versions exist. If using the common 3 bolt type skip right over cheap paper type gaskets and buy the aluminum kind or you'll be replacing them again and again. A crossover pipe like an H or X helps equalize the back pressure on the exhaust banks to promote better/ equal flow. Chambered mufflers hurt flow but sound good, fiberglass packing kills high frequencies.
Many people simply buy a Pypes G Body kit but you can buy a "box of bends" and put together a nice setup with only a couple of hangers. Or skip the kit and just buy the exact pieces you need. You can easily do this for $300, less if buying used, more if getting fancy with stainless. Headers: $125 Mufflers: $50 Leaves $125 for pipes, clamps, and hangers.
i'm an anti header kind so i would suggest hooker manifolds to avoid all the pitfalls of headers. also jegs has their own brand of trans x members for duals reasonably priced.
Those Hooker manifolds are nice. If that is still a bit out of your price point, using 350 stock manifolds and a true dual exhaust will be far better than a stock single exhaust. Both Jeg's and Summit have their name brand dual exhaust crossmember at a very reasonable price. I used the Jeg's crossmember with my TH350 but switched to the Summit crossmember (G Force copy) when I upgraded to the TH400.
great tips guys I appreciate all your responses knowledge is king. got the engine out of the donner car it;s a gm crate motor 2 piece seal old but low miles going to reseal it now I;ll keep you posted .thanks joe
Reactions: Sweet_Johnny
I'm considering the hooker manifolds and the [ 30525 jegs exhaust system ] anyone have experience with this combo ? also the engine is a gm replacement crate motor with oil dipstick provisions on both sides 2 piece main i want to reseal it any gasket recommends ? I;m putting on an old edelbrock intake and a mickey thompson valve coves any input would be appreciated thanks joe
that i cant help with cuz mine were custom built thru local shop from manifolds to tail pipes that were pre made by flowmaster.
