Good day. Any one have experienced the overlay for a G body . I’m curious about the fit. As well as what to watch out for! As I see a lot on you tube. But no Malibu. Thanks. Dez
Thanks. That said would I have to take the dash off to full cap this dash? Thanks DezThe Malibu/ El Camino dash caps were the most common available.
There were full coverage caps and partial caps which covered half of the dash. Go for the full coverage cap.
78-80 Dash Cover (center speakers, 100% coverage): 78-80 Black
www.dixierestorationdepot.com
I got a 79. Wonder if your experience would be the same for me . ??hmmmm. Dezin my 82 the dash has a large rectangle molding on the pass side i had to heat up the corners with a heat gun and reformed the corners with a socket that had the right radius to get the molding to fit
Great advice. Most appreciated. Dezthe 79 doesn;t have the molding i was talking about so you are good there . be sure to use black silicone by the windshield with a even bead from side to side because you can see it through the windshield
