Daniel;
If it's running rough or you are getting smoke under the hood. Check both check valves coming from the air pump outlet lines. Also check for a cracked line. You could have exhaust gasses coming out. You should hear a rattle, ...sounds similar to exhaust manifold leak.
We have a 305 1985 Caprice wagon in the yard. I'll go see if the air pump is there, it should be.
