How to remove pilot bearing
11,103
15,816
A buddy has a big block Chevy. He had a Tremec TKO five speed behind it and somehow managed to break it. Now he wants to swap to an automatic trans. He is stumped by getting the pilot bearing out. He used the standard Chevy bronze bushing. First I asked if he staked the bearing in place. He did not. I told him that is good as it should come out easy. I told him to fill the cavity behind the bearing with grease, get a drift the size of the input shaft, put it in the hole, and bang it with a small sledge hammer. The hydraulic force should pop the bearing right out. A busted input shaft make the perfect tool, and he had one. But that got me thinking. How else to get that out? One guy I know uses a slide hammer with a hooked end on both kinds. I use the roller bearing, and stake that in place. I grind off the stakes, and also use the slide hammer. It comes right out. I have heard of stubborn bronze bearings needing to be smashed out with a sharp chisel. He had the idea to use a tap that fits the bearing, and screw the tap in until it bottomed out, and pushed the bearing out. Sounds like a plan. It won't work on the roller bearing though. Any other ideas?
Reactions: Longroof79
I have various pullers to do this now so haven't used these methods in decades.
To use the grease you need to hit the input shaft then remove and add grease repeat 20 or more times and it comes right out just takes time. It is only moving a few thousandths at a time.
A variant that is a lot cleaner is to use wet toilet paper same thing jam it as full as possible and compress with the input shaft, add more and repeat many times.
I just remembered I have an OMC bearing puller that I used to remove the forward drive shaft bearings in lower units. The ID should be pretty close. I'll have to scrounge it up from my outboard motor tools box.
Yes, I almost bought a set like that on Fleabay. Then I found the actual OMC tool and bought that instead.
I've pulled them. By useing a bolt and and a piece of bolt shank! You stick the best bolt head you can find ( as big as will fit)into the bushing you hook the bolt head behind the bushing...you put a little short length of metal a sawed off bolt shank ect.in with the bolt to keep it jambed to one side ok? the first bolt has to have threads and be long enough to fit through a short socket 3/8 drive like a 15/16s or 1 & 1/4" the heads are now sticking up though socket drive end okay put a fender washer over the bolt end. ? (Sticking through socket turned like a cup) put nuts on the bolt or a joining nut and turn the nut/s tighter and tighter it wi draw the bushing up and out enough to get it out or loose ...works like a charm..
