Engine hoist ???'s
dickeymoore
1,011
145
Atlanta,Georgia
Is there a longer engine hoist arm that can be purchased for my engine hoist because when I go all the way in to remove engine from my 86 monte carlo ss the hyd cylinder is up against the front of the car which could damage the front of my Monte Carlo SS and the arm is all the way extended?Thanks
The longer the arm, the less the load it can hoist. What you need to do is to strip everything off the engine like fan, alternator, PS pump, etc. Remove radiator. Then adjust the chains to angle the front of engine upwards. You should not need to be on the longest extension. If the wheels of the hoist are hitting the lower control arms, before you begin- roll the front wheels up onto planks about 2" thick. . That gets you much needed ground clearance. In extreme cases, you could disassemble the front end, but I have never needed to do that.
I will just add that if you do extend the boom you need to extend the legs as well so that the load remains centered between the boom and the legs. Standard practice on Corvettes is to remove the engine from the side due to the long front end on most of them
My engine hoist is the same color as this borrowed from a visualillusion thread...mines has the leg extensions but I don't extend it out bc it hits the suspension. Thanx for the tip to gain some height but my leg extensions are probably frozen in place. As far as the boom, I have it set at the 2 ton mark which is at the shortest extension. I did have the hoist right up against the front bumper but only bc when I did own the SS, it was a 40 footer. BTW all this while pulling the BBC with the M20 still attached. I've always envisioned having bigger wheels in the rear would make it easier to maneuver. Bigger fronts and you lose ground clearance. Even thought about motorizing it with a small honduh engine which would actually provide some ballast in the rear. This is a cool idea but I don't own anything with a hitch... <click
When I pull the BBC out of my Monte I put the car on jack stands in the front so I have room to get underneath and pull the driver's side front wheel off and then pull the engine only from the side.
Yeah the legs dont extend out
Then that is all it can do. As Ribbedroof said, the length of the legs must match the boom. Boom too far out and you will risk tilting the whole thing over. Better to get some square tubing that will fit over or inside the legs. Then make extensions. Move the front wheels to the extensions. A simple through bolt can secure the legs. I have an old Harbor Break 2 ton hoist that everyone hates. But they still ask to borrow it.
What I did was put the front wheels on top of blocks to allow the hoist legs to pass under the front suspension.
I have the 2 ton HF model with the folding legs. Worth every penny of the $169 I pad 25 years ago. Two years ago I replaced the ram with another HF ram; they were clearing out their old models, so I got the one with the pneumatic pump for $89, also worth every penny.
It's also useful to have a big dude helping you, if only to stand on the back end of the hoist when you are pushing (er, pulling) your luck.
Make sure you disconnect any ground straps to the firewall. They will surprise you when they twist the motor at the most inconvenient moment.
