Body work
Montecarlo79
23
29
13
16
Fitting new piece for roof rail
The quality of welds is partly depend on skill and partly on the quality of the equipment and materials. A good ground and infinite settings helps tremendously.
View attachment 255155Keep grinding or just filler
So does electro contact tip stick out. Sometimes you have to grind the gas nozzle down a bit to get the correct stick out. I did it to my MIG welder and it improved my welds.
Also the gloves they sell for MIG welding are so thick they interfere with hand manipulation
Sometimes I use thinner TIG gloves when I MIG which helps to improve my results. If you do need to grind a lot, get the softer MIG wire for autobody work foe easier grinding.
Reactions: xylorex
