'00- '01 Jeep heads crack?
10,569
14,312
So my Son-in-law thinks his '01 Jeep head is cracked. He hasn't yet explained to me why he thinks so. But research indicates casting 0331 heads used on '00 and '01 models are doomed to crack between #3 and #4 cylinders. Lucky me- I have an '00. It is so bad a couple of companies are making better versions of that head. I just hope he quit driving it before the bearings and lifters were hurt. Anyone have to deal with this?
19,992
V-8 heads are poop VERY VERY common problem
19,992
Oh wait thats the 6 head?
never heard of that
I had a 2000 jeep 250k on the clock damm thing wouldnt die, then the transfer case front bearing exploded
Turbolq4
1,732
4,207
Nampa Idaho
The late model 4.0 I6 has head trouble. They crack because the exhaust ports were made smaller and moved up in the head to help the catalytic converter light off faster. Essentially they created a restriction to drive egts up. Thankfully the old heads will bolt right on. Unthankfully they need different exhaust manifolds fir the previously described reasons and they also have to be drilled and tapped for an idler pulley.
10,569
14,312
That's terrific. I read that later heads are better but need coil mounting brackets. My own has 175k and had lots of cooling issues but so far not the head. I guess it will depend on if he parked it before any other damage occurred. I advised him drain the coolant and oil, then fill with cheap oil and run for a few minutes to see if he has good pressure. If so and no expensive noises then drain that and refill with good oil and plan on getting the head. If crummy pressure and/or noises then it's probably trashed. Then again I saved that Trans Am 400 last Summer and it runs strong now.
8,827
7,783
I had my 5.9 magnum heads fail badly. It blew all the coolant out of the rad quickly. There is EQ heads for the Magnum V8, they flow way better than stock and are much thicker everywhere. It looks like Promaxx has a new I6 head. https://www.summitracing.com/parts/pmx-chr640n/ Claims 91 to 06 on one site and 87 to 06 on Summit but there are differences. Edelbrock's aluminum head is for 91-06 intake and 91 to 98 exhaust manifold or header.
10,569
14,312
That's for a bare head right? these guys too.
"Or use a later style Head ("TUPY"). 2002/2003 and up.
Aftermarket Head- Alabama Cylinder Heads (800-235-4323)- $510 includes shpg....Currently 75+ back-orders. New, thicker casting in weaker areas.
Clearwater Cylinder Heads (800-572-1963)- $455 includes core exchange & shpg. (in stock)) J&C Enterprises (800-266-5599)- $439 includes core exhange & shpg." These are complete with valves for $480- not bad. https://www.cylinder-heads.com/product/new-jeep-cherokee-laredo-4-0-0331-cylinder-head-complete/
8,827
7,783
No, supposed to be complete, $661 plus a $9.99 shipping charge.
10,569
14,312
i think the Jeep forum said Promaxx used to be Alabama Cylinder heads.
10,569
14,312
You are correct- they are assembled.
