04 Vette LS1 swap into Grand Prix Accessory fitment?
Shinobi68
21
12
Thanks for the replies. I'm looking for the rad/fan combination on Ebay now.
Shinobi68
21
12
Radiator might be cheaper at the local parts store, find the fans with the shroud in the junkyard.
Just doing a search is ICT Billet the bracket that some are using to relocate the AC Compressor to the top passenger side. The C5 as you probably know and like other LS accessories has the AC pump on the bottom, however the C5 uses 2 belts on the crank pulley and the crank pulley is in closer to the balancer than other LS cars (F Body etc.). I would like to relocate the AC unit up to the top, is it just a bracket change to relocate?
Built6spdMCSS
3,963
6,736
Florida Beach
See if they make a bracket that works with the C5 setup and keeps the main belt.
All LS stuff uses the smaller second belt to run the AC in the factory setup.
Shinobi68
21
12
Just curious does anybody know if the mini-Sanden AC pump and bracket work without having to notch the frame?
