85 Cutlass Brougham said:
Fuel heats boiler chamber -> steam flows from boiler into engine at 700psi -> engine converts steam into kinetic energy -> Kinetic energy drives a generator -> generator charges batteries -> current from batteries runs to a speed controller -> which powers an electric motor and turns the wheels or a transmission that then turns the wheels via the rear axle.
Remember that a well insulated boiler chamber will stay hot for a reasonable amount of time. So, even though it is heating the water, the fire need not be lit until the boiler chamber temp drops below a thermostatically controlled point. In this way, it uses the water to convert much of the heat energy into kinetic energy.
Yes, I work with bomb calorimeters and pressurized evaporators all the time. I still believe the boiler chamber is the weak link. You need something more dense than coal and the chamber needs to be pressurized. Like an industrial pressure cooker. In theory, you could even burn a mineral or mixture (somewhere between coal and diamond) at high enough pressure using a simple but effective vacuum pump. This would allow you to burn more dense fuel, keeping the boiler compact enough for today's cars. For example, if you use the right compound/fuel and pressurize it, you could burn a half a shoebox of it for potentially months at a time. Maybe 6 months, maybe a year. Nonstop.
Thing is, this still isn't practical. Hydrocarbons like gasoline combust easily. Free energy of a boiler with dense fuel is very high, it's not spontaneous...unless it can be pressurized. What this means is the energy cost to start up the process is much higher than to start an IC engine. But the long term benefits are greater in the steam example. Like a TV - if you turn it off an on every minute you waste more energy than if you kept it on all the time. So two things need to be considered - one is to either keep the boiler going while the car is sitting and store the energy in batteries, or two make a very efficient way to start the heating process.
But this is where the idea of wood gas comes in, you create methanol in a distillation process and can recycle it back into the engine using a spark plug like you said. This would cover the start up but then the vacuum would need to be powered by something also. Strong vacuum pumps take a lot of energy...
I say you can't use coal because it's not powerful enough, we'd be shoveling coal into our engines every few days/weeks (or less) depending on the boiler's size.
You'd also need a battery system or capacitor to store enough energy to power the electric motor for as long as it takes to heat the steam to operating temperature on start up. This way people have their instant gratification like a fuel injected IC engine.
