I have a '78 w/A/C and I"m running a set of Hooker Super Comp 1 7/8 tubed full length headers. I wrap mine so the finish means nothing to me as this car is purely for "F U N "....though w/ slicks and a 4.10;1 rear gear it's well into the 10's! I no longer drag so I'm running the A/C, a 3:73:1 gear and a tight 3400 RPM converter to make the car very suited to cruising around with the ability to run on the highway turning right around 3-3400 from 60-70 mph. With the looser & higher stall converter & 4:10.1 gear driving on the highway for any length of time truly sucked!
Now...the good about these headers......I run the headers into 3" stainless Pypes X pipe, with dump pipes into a pair of Flowmaster 40 series mufflers then into 3" stainless Pypes tailpipes. I literally can easily run the tach to 7200 + RPM with this set up without even opening the dump pipes! If I had known I could get this performance through the pipes I never would have gone with the x pipe with dumps!
I use copper header gaskets & allen headed bolts to attach the headers, without much in the way of difficulty getting to every bolt head to tighten them. Thanks to the copper gaskets, I've never had an exhaust leak after tightening the bolts 2x after initial install.....and this has been years, literally! I also have very little trouble changing the plugs....way better than most other small block headers I've ever dealt with through the years.
The bads is simple. One singular issue, but it has zero effect when driving but makes parking lot maneuvers a bit tougher..... these headers have 1 tube on each side that goes outside of the frame rails. This is how they got the equal tube volume as well as why these headers make working around them a lot easier than normal small block headers. The issue is you lose a lot of turn with the front wheels...not an issue when driving but turn the wheels too far while maneuvering at low speed and you'll have a tire into the tubes...left side when turning hard left, right side when turning hard right. If this isn't an issue on your end, these headers are the best! I've never had an exhaust that offered the same E.T. THROUGH THE PIPES VS open headers before in my life....I know for a fact these headers allowed me to get the incredible performance I get over 5500 RPM as well.......incredible performance! The speed at which my engine (full roller stroker (383), Brodix heads) twists up after 5500 with these headers compared to others isn't even remotely comparable! I also used to be able to feel my peak HP @ 6800...not anymore! I've far exceeded my red line a few times as this engine pulls so damn strong in the high RPM range that I can't begin to feel any peak that I was able to not only feel but HEAR with smaller tube headers, different flange etc etc.
I am "looking" to see if anyone ever offers a set of G body headers w/ 1 7/8" tubes that allow retention of factory AC box and don't go outside the frame....but that's it....looking. While interested in knowing what is available today is nice, It would take an awful lot for me to opt to change out these headers.
PS If you wrap your headers prior to putting them in the car (except the removable pipes on each side, of course) you can get very good, symmetrical installation of the header wrapping that is by no means as appealing as stainless but at the same time don't detract any from the underhood appearance...though this may just be my opinion.
Kirk Bonanny ASE cert MASTER tech, 30+ yrs exp
[email protected]
