If I get a one wire alt can I snip the wires from the old harness for the 3 wire setup? Actually the harness has 2 wires and one goes all the way to the fuse box. Can I clip them without any problems down the road?
I wanna clean up the wiring a bit by adding a 1 wire alt. I know its just like one or two wires less, but hey it should look cleaner and cleaner is what I want. Isn't 1000- 1500 rpm an average normal idle? If it helps, I have a sbc 305 in my Regal now.nycutlass said:i wouldnt cut them wires .if them wires are trouble free its better setup than a 1 wire setup.down fall with a 1 wire setup is that is has a high draw when engine is off ,also when you start the engine you have to rise idle around 1000-1500 rpm just to trigger the alt to start charging.
I haven't bought one yet but I can get a link if you'd like. I was actually thinking of clipping the wire a bout a good foot from where it goes to the firewall into the fuse panel, just in case I have to splice a wire back. I just thought id ask the G Body guys before I mess stuff up.nycutlass said:you do what you want ...stock motors around 1,000 rpm is normal idle ,in gear around 700 rpm for a stock setup .i just wouldnt cut them if they work correct .....what style 1 wire alt did you buy ?
Hmm...decisions decisions. I really would like to snip the one wire if it won't cause problems for me later since I won't be needing it. What is that wire for is what I should me asking. Is it for the stock motor? There's guys using the same alts on another forums website I'm registered to but nobody has answered me there.nycutlass said:its up to you ...it will work ...you have a couple options now to pick from .
