Wow I am surprised by some of the fitments that you guys are getting. For my 83 monte, I have 28.5x11.5 phoenix F/X bias ply slicks and both sides stick out. Remember though that I'm using a ford 9" rear with stock monte bracket attaching points. I have to use a 3.5" backspace rim on pass. side on a 15x10 rim, and a 4" backspace rim with a wheel spacer (don't remember the thickness, .25" maybe) but through experimentation it is what was needed to maximize space while not rubbing. I could see my inside sidewalls had the rub ring so while I dialed in the combos I sprayed grey primer on the rub spots on the frame until I made passes down the track and didn't see the primer rubbed off at all. My car launches straight with the use of an air bag on pass. side only, which controls the "torque launch", so when it leaves the line the front end lifts level, not twisted driver's side higher than pass. side (which leads to more tire rub problems). So I have 2 mismatched rims out back (weld draglite on pass. side, cragar ss/t on drivers side) but oh well, it's dialed in.
I did a thread on here describing the fender flare project I did on my car. The slicks sticking out was wreaking havoc on my car (rubber, rocks, gravel etc. gettting thrown all over because the slicks stuck out). They really work well.
Kevin
Kevin
