12 bolt in a 85 regal question
muthstryker
46
Hey guys new to the site, long time lurker. well im getting ready to buy an 85 regal limited from my friend and i have a 67 GTO, well im not useing the 12 bolt rear end on the GTO, im going with a moser 9 inch.
my question is:
how much do i have to shorten the 12 bolt?
i know the mounts are at a different angle but i saw that umi has parts for it. so i think i would be using those.
Thanks.
Matt
you dont have to shorten, it will be an inch wider each side. just looks wider and limits what wheels you can clear fender with when going wide
I think Southside Machine has a set of LCA's that adapt an A Body rear to a G body with no cutting. They are around $300 IIRC.
shorten it 1 5/8 of an inch per side and use 62-67 nova 12 bolt axel. that is what i did works out great .will use same offset wheel as front.
I am selling a set of SSM bars to do this,check the classified for pictures.
