15" x 6" or 7" Rally II's on a G-body?
noooooooooooooooooo
301 B-Bodys had the 4 3/4 bolt patten while 350's and up had the 5x5
Wow, I never knew that. I don't remember there being a rotor difference from my auto parts days. Another reason to go Pontiac and go often I guess
I just did a quick check on RockAuto. On a 1980 Catalina you could have gotten either bolt circle. The 5 x 4.75" one is with the 11- 1/64th front rotor with 9.5" rear drums and the other is the 5 x 5" with 12" front rotor with 11" rear drum. Engine has nothing to do with it. So the snowflakes could be either pattern.
Reactions: fleming442
in 1978 the option was because of the engine
"big" engine got big brakes larger bolt pattern
I know alot of people dont believe in the small block big block Pontiac
but there is a difference in the deck height between the 301/366 which is 9.137
When the common 350/400/455 have 10.24
When people talk small block/big block Pontiac the 265/301 are never part of that conversation. Of course the RA5 (303/366 etc) is also excluded. So I back righteous indignation when people refer to any Pontiac as a big block. Plus, if the same people are talking about a 326, 350 or 389 the call it a small block.
Well when i talk about Pontiac they are!
Simply because they are
