As long as there aren't any major rust issues, then it could be a good buy. The car isn't totally unit body, there is a subframe at the front. If the rear unit body is solid, then unless you're building something really strong, a pair of subframe connectors should do the trick. Most of the '70-'81 F body suspension & brake stuff will interchange. Hope it works out OK for you.
