1978 Buick Regal Limited Door Trim
RegalX78
71
38
I have a 1978 Buick Regal. I picked up a drivers door from a 1980 Cutlass as they are the same door. It's rust free and mine has rust in the pinch weld.
Can anyone tell me if the trim tabs on the bottom of the door are the same between the Regal and Cutlass? I have a Limited with the larger trim. There are 6 sets of tabs on the bottom of the door.
i don;t have your answer .since you have the door compare the body lines between the two maybe it might fit then measure the studs for the moldings from one to the other i doubt they are the same
Yeah.....the car is currently in winter storage....
