There are 2 mounting holes in the plastic piece the clock bolts into. The optimum way to get at those 2 holes is the entire vinyl surround needs to be removed in able to see and get to these holes. That does involve a bit more work due to the LH bezel needing to be removed which in turn the knob for the headlights needs to be removed. I've seen it done where the part of this surround that covers the 2 holes to fit the clock in is cut away so access to the clock is easier and alot less work.
Some 79's have the wiring already in there for the clock, some don't. I went through the effort to install an (analog) clock in my 79 Calais which never had a clock in it. I had the entire factory dealer installed clock package wherein it was equipped with the jumper wire which I used. It was years later when I accidentally found a plug for the clock was already in there and could have been used. For my black 79 Brougham, I installed a correct (rolling drum) digital clock and again, this car had no clock. However, this time I thoroughly checked to see if there already a plug in there ready to go. Not in this car.
Quick question dg, you placed in LED bulbs, do they dim when you dim the other dash lights or do they stay the same intensity no matter what setting the dash lights are on? Thx
