1980 Olds 442 interior
pagrunt
7,871
Elderton, Pa
For '80 I have 62 camel for the onlt tan shade. Not sure what name Olds used but the code could help cross numbers.
pagrunt
7,871
Elderton, Pa
I assume I can find through the Vin?
The body plate on the drivers side of the cowl will have the color code for interior & exterior. You'll be looking for 62x for the color/trim of the interior. The 11L & 57U should be for the upper & lower exterior colors.
Kelvin's80442
Thread starter
Apr 19, 2020
237
Ste Rose Manitoba
I have 11L and 11U and 8X2 B51
I will try doing a vin search online
69hurstolds
6,633
1980 Calias, built in Lansing, scheduled for build 2nd week of June, 1980.
That "8X2" is actually "BX2". Lower body side moldings. Snake blinders. AR9- Reclining buckets, CC1- T-tops. B51- lower wide rocker molding. If memory serves, this is the little strip between the wheel wells UNDER the lower body side moldings. Kind of a 2-piece deal there. Why? I dunno.
The 55M is gold stripe (separating the white/gold) and the L is for Lacquer.
You should have something on the cowl tag, right above the bolt. 2E is the last part. Right next to the 11L. It's likely 62E. Non-vinyl interior, Dark Camel Tan, as Oldsmobile would call it.
Again, that's my best shot.
Kelvin's80442
Thread starter
Apr 19, 2020
237
Ste Rose Manitoba
Well thank you for the answer!!!!
