What is the hang up with buying motor mounts? He said he had a $6500 budget. "Keep it Buick!", oh wait its an Olds. There are alot of choices out there for these cars which makes them great. The trans would need replaced anyway behind a V8, and the rear would need beefed up to make the most of the upgraded power. Hard to go wrong with a 350 chevy.If you have a car with a 3.8, a Buick 350 will literally swap right in. Don't gotta change anything. These, with mild upgrades can be pretty stout little engines. The are stronger and lighter than smallblock chebbys. Just the aftermarket hasn't embraced them as much. TA Performance is pretty much your only option for better than stock upgrades. For around 3k, including the motor, and trans I got (trans was junk btw, but only paid 75$), you can get it bored 0.030 over, hotter cam, I suggest if you were to go with a flattappet get a comp 268H kit. Lifters, chain, cam, springs, etc. Flat top or shallow dish pistons, basic valve job (or port if you know a guy who knows how to port Buick heads. Chevy tricks wont do well on buick heads), some headers a GOOD rebuild Q-Jet (everyday performance I recommend), and you have a pretty stout ~300-350horse smallblock with big block torque. Sure Chevy's are super cheap and everywhere, but I see them as over used and boring. Also, a Buick 350 has the same bore as a 3.8, 3.800 inches, but with a 3.85 stroke. You bore it .030 over, you get a nearly square engine. Just my two cents.
It's just the easiest swap. You can reuse everything. Everything from the front of the buick 3.8, timing cover, pulleys, water pump, fuel pump, etc will swap over to a Buick 350 and vice versa. With a Chevy, you have to reroute wiring, fuel lines, probably A/C lines, get new motor mounts, new brackets, etc. There is also the option of an Olds 350 or 403 if he wants to keep it oldsmobile. I'm just tired of people shoving chevy's in everything. It's boring. You don't see a Buick Olds or Pontiac G Body without a SBC hardly at all anymore. He can do whatever he wants, it's his car. I'm just giving an option that would be the least labor intensive as far as the actual swap itself goes. And the rear would be fine, hell with those low gear it probably has would balance out only having a three speed transmission. IF he could get his hands on a Monte SS rear end.. or an S10 carrier I believe fits in the housing with little trouble. Or, if his budget is 6500 like you said, he could just get a new rear or a Ford 9 Inch, 12 Bolt, the list goes on.What is the hang up with buying motor mounts? He said he had a $6500 budget. "Keep it Buick!", oh wait its an Olds. There are alot of choices out there for these cars which makes them great. The trans would need replaced anyway behind a V8, and the rear would need beefed up to make the most of the upgraded power. Hard to go wrong with a 350 chevy.
